android upgrade w203 c220 cdi a coupe 2003
That depends on what you have already?
DMK/Happy
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
What type of unit do you currently have fitted? ;)
Nothing!The last owner removed his upgrade,(was pioneer I think with sat nav) all that remains now is the empty space where the origional mercedes radio was and the wiring clusters with one extra live feed wire coming from the fuse box,(he said it was for a live pulse for his DOUBLE DIN SYSTEM. Thanks
DMK/Happy
DMK/Happy
AnthonyUK
Alton, Hants
C240 estate 2002 and a Nissan Elgrand E51 ser.3
There are some on Amazon but do your research if you want to avoid disappointment.
This would be the minimum spec. I would want to use. I can’t vouch for this brand though.
hizpo Android 9.0 Car Stereo DVD Player 7 Inch Car Radio RAM 4G ROM 64G GPS Navigation for Mercedes-Benz C-W209 / C-W203 / Viano/Vito/Vaneo/A-W168 / G-W463 / CLK-C209 / W209 https://www.amazon.co.uk/dp/B07X4Z6P98/ref=cm_sw_r_cp_api_i_fD-tFbFNXQET1
DMK/Happy
DMK/Happy
Ok!Thank you for the advice ,there are so many listed,it can be a bit confusing to say the least.The one you posted has Mercedes-Benz CW203 listed.
mioba
Nottingham and Köln
what an amazing price that unit is.
If it fits or not you should contact seller for dimensions and check your dimensions too. You may need a surround to finish it off. Not sure where you would get a surround that matches your car and the unit.
anyway, IMO at that price I would give it a miss (questionable quality for me) or buy 3 - to have some spare.
DMK/Happy
DMK/Happy
Thank you for the advice,think Halford's supply finishing surrounds perhaps....
AnthonyUK
Alton, Hants
You would also need a wiring adapter with the unit you mentioned.
The really cheap one you linked to is underpowered and would need adapters to fit whereas the one I showed is 3x the price but has a decent spec so will at least be useable, fit without a bezel and come supplied with all the cables to be plug and play.
These units need 4gb ram 32gb storage and an 8 core cpu ideally.
DMK/Happy
DMK/Happy
I will have a long look at the info you sent asap,much appreciated and saved. ......
DMK/Happy
DMK/Happy
View larger
Check out the specs on this.
XBS 8900G Car GPS DVD Player
https://www.electrodirect.ie/double...yer-62inch-touch-screen-bluetooth-usb-sd.html
6.95inch
TFT LCD monitor(RGB solution)
Touch screen with Graphical User Interface.
DVD/VCD/CD/MP3/MPEG4/DIVX/CD-R/WMA/JPEG
Built in TV tuner, PAL/NTSC or SECAM compatible
Built in FM/AM tuner
Built in bluetooth function
Built in4X50W amplifier
All touch screen
1 A/V input(1 video, 2 audio), 1 A/V output(1 video, 4 audio).
Auto rear viewing function
Mute at telephone calling
Picture adjustment (brightness, contrast, color, settings)
Full-function OSD Card Size
AnthonyUK
Alton, Hants
View larger
6.95inch
All touch screen
I can't see any technical specs. and is it running Android?
The rest are pretty standard across all these Android units tbh.
I think you can get better for the price IMO.
DMK/Happy
DMK/Happy
  • #17
Thanks!I will check if it is running Android,just in case.Appreciated,
DMK/Happy
DMK/Happy
  • #18
Should android d/d radio unit running on android be wired to turn on at acc? or at ignition position only?
DMK/Happy
DMK/Happy
  • #19
Dash cam! causing resistence,static noise to some radio stations.is there a solution to fix this ?
Yes, better power supply lead for the dash cam, ferrite beads added to the power leads and separation between the power leads for the dash cam and RF leads from the DAB
