Another E class alloy wheel thread
Nidge
Oxford
2013 C250 Coupe AMG SPort Plus
Hi, I've just "won" a set of E211 5 spoke alloys from ebay which I intend to fit to my 1999 E 240 Avantgarde. They ar 7.5J, 42 offset and pcd of 112. Am I right in thinking that these will fit straight on using the existing alloy wheel bolts? Thanks in advance
clive williams
Nidge,
The wheel is about the right size; W210 offset is 41mm for the 7.5J. I doubt whether the 1mm will make any difference, all other dims quoted are OK. However, the inner clearance on the front suspension is quite tight so finally check when you've mounted a tyre.
Malcolm (TV) posted some info on wheel bolts taken from the parts manual so perhaps he can check the bolt compatibility?
Clive
500E
E320CDIT210
clive williams said:
Nidge,
Clive
500E
E320CDIT210
MB bolts are 28mm for alloys, I don't know if the new wheels have 14mm holes, if 12mm no problem. MB charge£1,80+ each where as firms like Topgear take £1.00 inc each, very nice chrome finish too, As you rightly say Clive off set OK.
Always play safe when changing wheels, spin them while car is on the jack.
Malcolm
N
Nidge
Oxford
Ah, I hadn't considered that.... presumably 14mm holes would be a problem?
N
Nidge
Oxford
Update:
The W211 wheels do indeed use 14mm holes, and require a shorter bolt than the standard W210 alloys, however this was quickly remedied by Murray Systems who supplied the correct length 12mm bolts which have an R14 cup to match the wheels
Nidge said:
Update:
Murrey systems are OK and I believe they only charge £1.00 each.
malcolm
N
Nidge
Oxford
And here's the end result:
cockrobin
redditch, worcestershire
new bolts to relace the old ones from mercedes are just a joke, gone is the nice chome finish, and in with the cheap and nasty galvanised ones, they are probably sourcing from China. For my 5 year old E240, i have got the chrome ones re polished.
clive williams
Cockrobin
How is it that you have chromed bolts on a W210? Our T210 had rusty poor galv ones. Interesting though, I de-rusted them and sprayed them with cold galvanizing paint and came to an as new finish. The paint finish doesn't seem to attract the dirt as the rest of the wheel is almost black with road crud and the wheel bolt stand out in clean silver colour???????!!
Clive
500E
E320CDIT210
