Another which brake disk thread
Trev1964
Lydney
CLS 250 cdi estate 2013
I put a full set of Brembo discs and pads on my car last year. Done 3000 miles since. I drive like a nun and do no hard or high speed driving. My commute is 1.5 miles each way.
Fronts have warped. Became obvious a few weeks ago after a very rare trip up the motorway.
Won't be buying Brembo again.
Janchee
Ex W213/2016/220D 190
Same here. Mercedes OEM for 213 AMG styling pack is brembo. Warped discs all over the place
Gazwould
C250 CDI
This is the second car and third set of brembo disks I’ve had warp so won’t be having them again.
If the Merc ones warp I'll condem them to death .
V6Matty
V6Matty
Newark, Nottinghamshire
  • #24
Lol, a little harsh but justified I guess.
Looks like I’ll be giving ATE a try this time, just going to give ECP a couple of weeks for one of their daft %off offers to come up, I’ll have to take a look at low dust pads now too as I’m sure the existing ones will be trashed
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I must be unusual, 58K on my 212 still on the original discs, pads changed at 37K.
Two CLK's sold at 120K & 115K, only one set of front discs on both.
The wife's 171 200K sold at 90K, only one set of front discs.
V6Matty
V6Matty
  • #26
My old 211 had one set of disks in the 120k miles and 6 years I had it so not unusual to last a good amount of time, I know the current ones are likely fine just no longer the correct shape
If you’re replacing discs always replace pads at the same time otherwise the wear on the pads from the old discs will be replicated in the new ones.
Janchee
I’m exactly the same. Warp started when I actively used the distronic for peak traffic when travelling back home. I would think that all the stop start traffic was too much for the car. Funny as I’ve never experienced it in any other vehicle.
I’ve fitted genuine discs and pads but dealer just says they can’t guarantee on fitment so the 2 year warranty is pointless. Just going to get the dealer to fit them as I can just bring it straight back when it warps again. I got a good discount and although it’s a bit pricier; the 2 year warranty actually stands
I use Distronic all the time and have yet to have an issue.
V6Matty
V6Matty
  • #30
Was doing a little checking earlier today and came across Borg & Beck, anyone know much about them?
that's a name from the past! Knew them for commercial parts more than cars to be honest, their stuff was decent
V6Matty
V6Matty
  • #32
Yeah, running since 1903 reading up a little, may be worth a punt as it’s around £40 cheaper compared to Pagid/ATE
flowrider
SL500 (R230)
I use Brembo on most of my cars and never had a problem. Last year I put a set of rear Brembo disks on my Audi S5 and have not had any issues.
brandwooddixon
Wolverhampton
S63 Coupe 2014
My early MBs used to suffer from warped discs, since I started to get into the habit of braking my speed down to about 95%, release then reapply to stop and only use the parking brake once stationary (especially when exiting a motorway), I've never suffered the problem again.
I think that most issues are caused by pad pressure on the discs as they cool from a high temperature - some will be pad material transfer, but also any uneven application of pressure will encourage the disc to warp.
Janchee
This is the exact thing I normally do when driving. My judder issues only came about when using the distronic functionality which, in my observation uses the brakes a lot more than I would. I don’t blame the system as it goes off what it knows.
AnthonyUK
Alton, Hants
C240 estate 2002
I’ve always used Brembo without an issue. The last set I bought though I have concerns that they are genuine.
The box had no hologram seal or QR code on the label.
I wonder how many issues could be from non-genuine parts?
Ricardo_e220
Newcastle upon Tyne
R170 SLK230k 1999
Just to jump on back of this, think I’ll need to do the brakes on my CLS.. sitting around more due to covid and all that stuff.. when I take a right turn I get a whooshing on and off noise...
checked and the discs are heavily lipped front and back.. only 40k miles :eek::rolleyes:
who other than eBay (never sure get right stuff) ecp (never sure will get right parts either o_O) are recommended... I’ll try and avoid Merc unless no more expensive as I’m not exactly flush for car spending due to covid...
McDonald
Surrey
SL500 2004
Always worth checking with MB Grangemouth.
