Me too. It has a bigger engine than my W210 and yet it uses a smaller battery.Surprised it only had a 60Ah to be honest. My 129 is 100Ah and is based on the 124.
The 60Ah is confirmed in th Heinz manual.
The battery space in so small making it difficult to use a bigger battery.
I will try to fit my 75Ah next week.
Must be running out of beans ...
Just use HP ones… they’re just the same…Must be running out of beans ...
The beans are ... the sauce isn'tJust use HP ones… they’re just the same…
As long as it fits, has the same chemistry(as the old one) and the same or better CCA then it is better that a 60Ah.I assume using a 75Ah battery should work well with my W124 which is designed to have a 60 Ah battery (I have the 75Ah battery from my other car)
Any disadvantage of that?
