Any genious there Problem Problem 230 Engine Cut off
230 1989 model. engine cut off on traffic signal or in slow driving...stationery position RPM goes up itself makes gerkes...if not hard brak press...car move fast forward....
Check the fuse in the Over Voltage Protection relay. It's located behind the battery. It's silver in colour and has a flip open lid with a fuse inside.
Problem: Engine cut off on every traffic signal or going slow......
Solution: Over power protection relay is replaced ....Problem fixed.
Over power relay is behind the batter...remove black plastic sheild and right hand side plastic square cover. Pull up this cover and find a relay underneath with clear cap on the top.
Orignialy my 230E has relay with one fuse on the top but when I could not find the relay with one fuse relay I install the relay with 2 fueses it work perfect.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
