any ideas guys
BABASON
london
hi senior members,
question, vehicle is a c200k wdc203045. has command, full electric seats and steering, adjustment incl memory 2002 reg. vehicle
(1)automatic door locking, inoperative when driving off
(2)passenger side mirror not tilting down in reverse.
(3)easy entry on steering wheel does not work
(4)exterior mirrors do not fold when vehicle locked with remote.
customer says all these items worked, untill he had a flat battery and replaced battery. All these items can be switched on and off in instrument cluster setting menu.... and are ON.
No relevant faults in short test (that I can see) am I missing something basic or a common issue here.
your various thoughts would be appreciated b4 I start getting too deep Sirs.;-)
thanks in advance
whitenemesis
CLS55 AMG '05
Point 2, have you set the reverse position for the mirror? This may well have been lost when the battery was disconnected.
When you first bring up the cluster options, are they set on?
B
BABASON
london
damn fastest response ever thanks.
iam not sure if that was actually an option in the cluster menu but when i scrolled through i made sure that all relevant options were set to ON
whitenemesis
CLS55 AMG '05
To store passenger mirror parking position:
1. The vehicle must be stationary.
Turn the electronic key in starter switch to
position 1 or 2.
2. Select passenger side mirror& and adjust the
mirror to view the curb.
3. Push the memory button “M” (4).
4. Within 3 seconds push bottom of adjustment
button (3).
The mirror should not move.
Repeat the memory procedure if the mirror moves.
Note:
One stored parking position is available for each of the
two electronic keys.
This is only possible if you select “ON” in the menu,
“SETTINGS KEY-DEPENDENT”, see under individual
setting menu “CONVENIENCE” – “SETTINGS KEYDEPENDENT”,
see page 134.
B
BABASON
london
thanks
will do what you have suggested and report back.
thanking ya.
