Any one in Northern Ireland can take a broken glow plug out
range rover
Northern Ireland
E Class Blue EFFICIENCY 250 CDI Sport 2013
anyone in Northern Ireland can take a broken glow plug out
I think you mean can anyone in Northern Ireland take a broken glow plug out, I would try Willie McGaffin, if you have the head off, Jack Ballance from near Glenavy can do wonderful things in engineering, I presume the head is still on, if so Jack might still be your man.
mercmancdi
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
Thanks head still on ,, could you give me contact number for them..
Even send by private message if you wish.
range rover
Northern Ireland
anyone in northern ireland can remove a broken glow plug
willie can be got on 07860927842
mercmancdi
mercmancdi
Thanks it appears that the advice is let it be as the other 5 are working.
Contacted Willie and that's there advice too .
Would have liked it fixed though as now I am frightened to try to take any out in case I break 1 then I would be down to 4 working. :(
range rover
Northern Ireland
I know exactly how you feel, funny Willie gave me similar advice when I mentioned that the temperature was settling down around 60c 'If the heater is going leave the thermostat alone',I however took the advice from forum members, notably Malcolm, and have a warmer car, better mpg and I know the thing is right, so I have peace of mind.
You could give Jack a call, last time I saw him he had a Merc and possibly has had the very same issue as you have.I don't have his number but it will be in the book, he is on the Lisburn Road out of Glenavy and what he doesn't know about engineering isn't worth knowing.
mercmancdi
mercmancdi
Fair dues Malcolm's seldom wrong he has been great to me .. Along with other very good members.
This forum has saved me Many pounds and sleepless nights...
Rockall
Donegal Ireland
Many
Any one in n.ireland take on the job of removing a broken glowplug from a s124 e300d 1995 model.........
Good evening
Well there are two ways of looking at your problem.
One - if your car is a run around and something that you may change within the near future then I would leave it and leave well enough alone
If, you intend to keep the car for a while - and a diesel 124 has to be one of THE cars to keep - then I would suggest getting it removed by whatever means is required.
If that eventually entails drilling and using helicoils or some othermake so be it. It is a small price to pay to keep a fantastic piece of engineering in tip top shape.
Regards
Bill
