Any one know how to remove these plastic panels?
hod05
E 250 cabriolet, 190E 2.0L
Hello
Wanting to give the car a good clean and around the boot there are plastic trim pannels that seem to be dirt traps. Car is a 2010 cabrio e class.
Anyone know how to remove them?
Looks like little plastic rivet type things, do they just pop out? They don't have a hex or slot for a screw driver
Those rivets lift out to remove the locking pin then the panel should pop off looking at that pic.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
As above they do just pull out carefully. The pin can be pushed back out so as to re use them.
The part is “expansion rivet A 000 990 8492 should you need any.
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
With some of those type retainers, you have to push the centre pin inwards, and then the clip pops out,,,,,problem with this kind is that sometimes, its impossible to find the centre pin afterwards.....:geek:
star
Reading
Smart + others :)
Those pins pull up, shaped like a T.
