Any pet hates on your MB?
Sasha94
Bangor, North Wales
2003 CLK55 AMG
The bootlid design catches me out on the 209, any decent coating on the paint makes it drip puddles onto the boot carpet, lack of cup holders in the front (though it has them in the back!), the lack of a mono adjustment setting on the climate control so you have to do both sides separately, the massive clock but lack of calendar. Volvo also guilty of this. 2 clocks in the car and no calendar! My Audi had a clock and a calendar, it’s always handy.
All nitpick points though and the clever design touches more than outweigh the minor misses.
EmilysDad
Bury Lancs
ML350
...., the lack of a mono adjustment setting on the climate control so you have to do both sides separately, ......
This surprised me when I bought my Merc when even my humble Vauxhall Omega used to change the temp on both sides of the car when altered from the driver's side. Any adjustment from the passenger side stayed as set until the next time the car was used.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
That's been sorted now. Mine has a "Zone" button which, when selected, means that the passenger side mirrors the driver side setting. Adjusting the passenger side means it reverts to independent settings.
EmilysDad
Bury Lancs
ML350
The auto climate on my Omega did that all by itself ;)
turbopete
Spennymoor
asit does in the Mondeo, unless you switch the 'mono' function off then each side can be set independently
MalcQV
Manchester
Mercedes CLA200
The IR window closing/opening. I've had it on other cars that work through an RF system. IR is just pointless to the point I don't use it at all. :p
Wipers, namely automatic wipers. I've had them on my previous Alfa 159 and this. I used to complain bitterly about what a waste of time they were on the Alfa as they had their own mind. Sometimes they'd wipe when there was no need and then not when there was.
This MB seems worse. I think in both cases it has to do with how clean the screen is to start with. The MB has a very marked screen (stone chips etc) and the wipers although not worn seem to smear. So when I switch the wipers on they just wipe continuously until I get annoyed and turn them off. Effectively there is no intermittent. :(
There are three small cracks in the windscreen two of which have occurred since I bought it. I need them fixing or ideally a new windscreen which might make a difference. New wiper blades also on order.
Lastly the wiper switch itself. I can't see what it is set on because the steering wheel spoke covers it. This is only and issue when I start the car because once I'm moving due to the problem mentioned they just wipe anyway after a minute or so :D I find myself twisting my head at daft angles trying to see past it.
L John
W204 C350 Petrol Elegance
The remote buttons are too easy to get pressed when it's in a pocket.
If you unlock the car doors by accident it re locks after a short period but the boot just flies open and stays open with a long accidental press of the boot button.
As Emilys Dad said earlier, it works over a huge distance, this means I have to take the keys out of my pocket and put them on the table even if I just stop for a coffee at a cafe.
A double press within 2 seconds would have been much better.
Srdl
Hampshire
Don't wear such tight trousers! :confused:
grayb
Kent
E350CDI (S212) 2010
The speedo is hard to read in our S212 when its a bit gloomy outside but not dark enough for the lights to switch on automatically.
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
You know you have a switch don't you?
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
Yes this is one problem I have noticed, only in certain light conditions though.
My normal sight is good but I do need readers so not sure if non glasses wearers would notice this.
Robin
geraldrobins
gloucester, UK
C Class/2011/200cdi
Robin
I notice this as well and sometimes turn on the parking lights to illuminate the dash on my W204
anglaslt
Lithuania and UK
LHD B63S Brabus (CL63 AMG) and RHD BMW X3 M40i
Maybe try using the digital speedo? It's much easier to read.
grayb
Kent
E350CDI (S212) 2010
Yes, but then you lose the temperature and miles. All it would need is the instruments to be permanently illuminated... I mean, a grey needle on grey background - who ever thought that was a good idea?
turbopete
Spennymoor
those of us that have cars with such a system agree (mostly) that its a terrible idea (unless you have auto lights)
grayb
Kent
E350CDI (S212) 2010
I've had Citroens and a Lexus that had the dash permanently illuminated and never had a problem with it... The Lexus 'Optronic' instruments were the best. And the S212 has auto lights.
Larkone
NW Essex
C219 CLS 320CDI 2008
The HVAC system on my CLS is not a patch on my old Lexus (Gs300 2002).
