Anybody know the correct idle speed of a 230te auto?
Status
Not open for further replies.
Badshot1uk
Orpington, Kent
Hi all thanks for coming to my rescue again!
The question is as above really!
It seems to run ok at about 700 rpm but i think its a little low?
Let me know if im wrong!
Cheers again all
Paul :?:
Richard.Wilson
Paul,
I'm not familiar with the exact dates they made changes, but I expect you have the earlier KE-Jetronic (CIS-E) injection. If so it's adustable, and I believe that 700-800 would be quite acceptable when checked "warm" in "Park". I cannot see it listed in the Haynes manual..but that speed seems to ring a bell.
Mine tends to be about the same, but it's the later type which has a rotary idle actuator, to automatically adjust the idle. I must say I prefer to be able to set it myself, but we cannot have everything.
If she runs smooth, and doesn't die on you I'd leave it where it is. You will get less clunk on drive take-up and slightly better engine breaking in theory (only in circumstances where there is engine breaking).
Richard
Badshot1uk
Badshot1uk
Orpington, Kent
Hello Richard,
I managed to get hold of a manual yesterday and your bang on right! :lol:
I wont mess with it as it seems to idle ok just dropping off slightly now and again. I just thought that all other motors ive had seemed to idle at around 900rpm :roll:
Cheers matey
Paul
sunil sood
as per the brooklands car manual ,the 102 engine's idle speed should be
800 plus or minus 50 rpm-so anything between 750 to 850 rpm would be
ok.
hope this helps
:D :D
MW
Mine on a salon is 700-800, and it is very smooth. If all is well don't raise it as the gear engagement will be harsher (more work and wear on the brake bands) and lower tickover revs = lower fuel consumption.
Status
