Anyone help me with a part number? (Bosch o2 sensor)
ThinkPad
London
E W212; C W204
Upstream o2 sensor for CLS 320 CDI. Thinking if I can get a deal on the sensor, may aswel change it for peace of mind.
Mercedes refuse to give me the part number for some reason. I have seen an o2 sensor on EuroCarParts at approx £178, whereas the Mercedes part is £235.
The EuroCarParts is a Bosch item, but shows for the E Class rather than the CLS. Would it be the same part for my car? If not, any recommendations of where I may be able to get one?
EuroCarParts Part No.: 710221685
Help greatly appreciated.
Edit: Also found the above part on another site for £126. So if someone can tell me if it is the right part, would be great! Or tell me how I can find out!
T
ThinkPad
London
E W212; C W204
  • #2
BUMP
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
Why would you want to spend money on something you don't need? I can't see how having a spare O2 sensor would give you peace of mind.
(Unless you have had a problem diagnosed on a STAR, then I will get back in my box).
T
ThinkPad
London
E W212; C W204
To Clarify
Sorry the OP was in a response really to a previous thread of mine.
It came up as fault on the STAR, although there is no CEL on the dash.
I since have had it checked and cleared, and it re-appeared on OBD2 test machine. So the fault is definitely current. Although, couldn't say have noticed any ill effects, but having only just bought the car who knows - maybe I should be getting better economy or performance but just don't know it...
RUXLEY
surrey
CLS 320 CDI
exact same fault as you , did you get this fixed ?
T
ThinkPad
London
E W212; C W204
Sorry for the delay in response.
I have now had the o2 sensor changed. Mainly due to just being pedantic about things, and not feeling happy about having a current fault code stored.
However, after the change, NO difference at all in the drive, the performance or the economy. (May be lower economy in fact - but I attribute that to the cold weather rather than anything to do with the sensor).
When the mechanic changed the part, he did frankly tell me majority of these cars come up with this fault, and he actually advised me not to bother. We also have another CLS CDI in the family, which also comes up with o2 sensor fault of some sort.
CONCLUSION:
Leave it as it is. If the CEL comes on, then check to ensure nothing more serious. But if just o2 sensor faults, I really would not bother.
Hope that helps.
RUXLEY
surrey
CLS 320 CDI
CONCLUSION:
Hope that helps.
did the code go though after replacement ?
T
ThinkPad
London
E W212; C W204
Yes it did. In the past if I cleared the code it would come back after a drive. Last time I checked was a couple of weeks after changin the part and it hasn't come back.
RUXLEY
surrey
CLS 320 CDI
cheers might try and get it changed under warranty then.
EmilysDad
Bury Lancs
ML350
Mercedes refuse to give me the part number for some reason. ....
It's so you don't get the part number from them & then go online or to ECP ;) & buy it from them instead. Having said that, I have been given a part number from a MB dealer (the Smart side of MB) so I could check up on availability at A N Other MB dealership (Some MB won't discuss Smart parts even though some bits are the same ;) )
RUXLEY
surrey
CLS 320 CDI
Indeed £235 from Mercedes or £53 from motor factors genuine merc part :lol:
EmilysDad
Bury Lancs
ML350
You do need to be careful though sometimes. I've not had my Merc for long enough to be able to say for MB, but for Vauxhall bits it's generally cheaper in the long run to bite the bullet & buy OE rather than use pattern parts that fail early eg crank shaft sensors. And just because a part is made by the same firm that makes OE, it doesn't mean they're the same eg Heinz make HP beans, but they're different from Beanz ;);)
c15htn
Milton Keynes
'00 A208 CLK320 Convertible.
Emilys Dad, i don't think anyone on here would buy just any old motor factor part.....
They seem quite a discerning bunch and seem to aim for Bosch etc - which are likely to be good quality parts in their own right.
I must admit, for this particular car I've elected to do the same :D
EmilysDad
Bury Lancs
ML350
They seem quite a discerning bunch and seem to aim for Bosch etc - which are likely to be good quality pays in their own right.
I agree on both counts. ;) ;)
RUXLEY
surrey
CLS 320 CDI
