Anyone know what these are? **PIC**
Lexman8
Yorkshire, The French Alps & Quahog
CL500 (2001): Distronic, Bose, Keyless Go; Honda CR-V EX (2011)
On the front of my CL500, two units mounted just below the licence plate each with 3 wires (red, white, black) going in?
star
Reading
Smart + others :)
Looks like a laser jammer. ;) ;)
c15htn
Milton Keynes
'00 A208 CLK320 Convertible.
Think you might have to try and chase the wires and seewhere they end up....... might give you a clue?
Looks like a [STRIKE]laser jammer.[/STRIKE] automatic garage door/gate opener ;) ;)
corrected that for you. just in case anyone who is pro-speed trap minded is reading :wink::wink::wink:
star
Reading
Smart + others :)
Mine were parking sensors. :)
brandwooddixon
Wolverhampton
S63 Coupe 2014
I would go for the laser garage door opener, which incidentally is illegal to use when on the road as they have a tendency to interfere with Police Laser speed cameras. There will be a switch somewhere within the car I suspect.
Looks very like a garage door opener to me, you might also have one on the back to open the garage door when reversing into your garage...
roop_the_loop
E220 CDI BlueEff SE, 7G auto, estate (S212), 2012
Quite right, too! I asked earlier a question on how to get power for my radar detector (as the 'cigarette lighter' on the new E-class is hidden under a sliding cover), and half the replies were along the lines of "if you drove within speed limits you wouldn't need a detector" or something to that effect... :rolleyes:
Lexman8
Lexman8
Update and **another pic**
Thanks for all the replies. I reckon it's a laser thing as suggested.
I traced the cable back to the fuse box where it connects (badly) to a red/yellow wire thru a 5 amp fuse. I've pulled the fuse to disconnect the units.
Does anyone know what the red/yellow cable connects to?
The cable bundle appears to then enter the cabin behind the dashboard but there are definitely no switches or additions of any kind visible.
There's also a dodgy looking 10 amp fuse with another cable going into the cabin and no obvious use for it. I might pull the fuse on that and see what happens.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
On my 211 the 'garage door opener', kindly procured by the previous owner, has a tiny little toggle switch under the dash next to the bonnet release handle.
Allegedly. ;)
Corned
East Midlands
My 'gun' on the front is completely different. It actually looks like an automatic pistol has been wedged under the bumper!
Here's the toggle switch.
Lexman8
Lexman8
Thanks again, Corned.
I double checked and there's no sign of a switch of any kind. With the fuse out and no obvious ill effects I'm gonna just leave it as it is now.
Corned
East Midlands
Probably the best approach!
Maybe they're not what you think they are after all? If they were laser jammers, why would you need two? And surely you would want to control them, i.e. only switch them on at will, so there should be a switch within easy reach you would have thought.
I wonder if they are parking sensors?
Mic
Oxfordshire
www.bennettgibbons.co.uk
MB SL500(2003), MB SLK320(2001), Volvo V70 XC AWD(2001)
There is no switch to my garage door opener.....it is permanently active and connected to my Origin B2 offering visual and audible warning whenever I am in the vicinity of a garage door.
Mic
star
Reading
Smart + others :)
My 'parking sensors' used to beep once when close to something. It also had a switch to allow you to turn it off.
s5tuart
2003 R230 SL350
The red wire will go to a switch somewhere, unless it's hard-wired to an ignition feed. In any case if it's all connected you should hear the self-test beep.
