ASR light and car ill not running right.
roblloyd
R129 1990 500SL
1990 500 SL , battery flat after not uSed for monthS. All good before , after charge ASR came on once i put my foot on the gaS. It like it in limp home mode. Never done thiS in the 10 year i have had the car.
ANY HELP PLEASE
Thank you
Does ASR reset after turning off then on?
Check the wiring harness, particularly looking for rodent damage.
In that case you may need to read codes with a blink reader (or STAR)
R
roblloyd
R129 1990 500SL
R
roblloyd
R129 1990 500SL
Must have a fault code. If it didn't the light wouldn't be on.
OK, once i put the battery back in i did all the codes before i started the car.Need to go back and do the code again. Update hen i do that. Thanks
R
roblloyd
R129 1990 500SL
1990 car. What did you use to read the codes?
Code reader = code 15 , 2 +3+4+6
Its a code reader that flashs , bought it off malcom before he pasted. Great Bloke , missed on here.
Any ideas Please.
R
roblloyd
R129 1990 500SL
Could not find the codes its not the same as the codes i used to have.
Found the codes on my old computer.
Code 14 =2
Fuel pump relay (circuit 87) not functioning
Code 14 =3
TN/TD signal (RPM) interrupted
Code 14 -4
Output for oxygen sensor heater control defective
Code14 = 6
Output for kickdown switch control defective
These are the 4 codes coming up. Now 2 cannot be a problem because the car starts its only when you put your foot down thats when the ASR light comes on.
Code 14 = 6 , this is the one i want to know about?
Output for kickdown switch control defective, ANYONE know what ans were this is.
Thanks for any help.
Rob
R
roblloyd
R129 1990 500SL
Code 14 =2
Code 14 =3
Code 14 -4
Code14 = 6
Rob
Sorry forgot to put this
Code 14 is , continuous fuel injection system (mas controller).
