On my E240, after a service, the distance to the next service was reset at 10,000 miles. The display did not count down every mile but after approx 100 miles it would change to read 'next service due in 9,900 miles'. However, it never changed at exactly 100 miles, most times it went approx 120 miles before changing and I was able to go approx 12,000 miles between services.
I traded in my E240 for a E320 CDI a month ago. The E320 had 9000 miles on the clock and was predicting the next service was due in 7500 miles i.e at 16500 miles. I've since done 2000 miles and the next service is still showing as EXACTLY the same i.e. it will be required at 16500 miles. Is this normal? It hasn't changed by even a mile or two, it's exactly the same. I know that because I wrote it down on te invoice and it hasn't changed. I thought the whole point of ASSYST was that it monitored how the car was driven and adjusted the time to the next service accordingly. Could the ASSYST be 'stuck' and not doing it's job properly? I've read elsewhere on the forum that mileage between services can be extended for a number of reasons, including the type of oil used, but mine seems to be 'stuck' on a fixed interval.
Any help/advice appreciated.
