ATF gearbox
isohail72
Manchester
Mercedes S320 CDI 2006
Hi Guys
When i gas the car it knocks, i mean if i try to put foot on the accelerator after chaging few gears it knocks
.. but if i do it smoothly, its ok.
Any advice pls?
Engine mounts, drive couplings, diff mounts.
That'll do for starters.
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
Second the above.......plus Auto or manual? If auto, how many miles since last transmission service?
isohail72
isohail72
Manchester
Its auto s320 2006. Dont know when ATF was changed
pgh13
Nr Leamington Spa
I'd put that on the list then. I had what's often referred to here as rumble strip noise on acceleration. Changed trans filter and flushed fluid. It's much better now
isohail72
isohail72
Manchester
Hi mate, any idea about the cost please?
pgh13
Nr Leamington Spa
Take a look at legitstreetcar on YouTube. He shows how duff engine mounts behave.
pgh13
Nr Leamington Spa
Hi, Both from Fleabay... the fluid is Smith & Allen - £88 for 20l and the gasket kit from KMSpartsonline. Only niggle was that the kit doesn't include the copper sump plug washer or the tamper seal for the filler tube.
