Audio 10 CD Aux
Jay Gee
N.Wales
Honda
Would anybody happen to know if an Audio 10 CD has an AUX. connector suitable for an MP3 input, and if so,do MB supply the harness/lead etc.?
Cole@MBS
www.mbssouthampton.co.uk
Don'T think it does Jay, might be wrong ( normally am )!!
Jay Gee
N.Wales
Honda
Thank you,Sam.(not going to try typing your user name)-you may be fairly positively correct here though. :D So,aftermarket,or Audio 20 probably.
Cole@MBS
not 100% sure if audio 20 has one???;) yeah, should have picked a shorter name!!
Jay Gee
N.Wales
Honda
Not shorter-just easier. Llanfairmathafarneithaf is simpler to type.Thanks for your prompt replies though.BTW do you prefer Sam or Mr. Unit ?
Cole@MBS
Not worried Jay, been called al-sorts before!!!
Myros
R107, S211, R170, C219
i think you might be able to do something
if it is the pre fibre-optic one. If that has a cd-changer control, then there must be an electronic input for the changer signal. All you'd need to do is work out which wires in the loom for the cdc were the audio input/output, and replace or piggy-back those with your mp3 input wires. Then select cdc and theoretically, bob's your uncle.
The only problem I have here is I've never had an MB audio that isn't fibre-optic, so i can't back this theory up.
Malcolm, one for you I think.
W
W203-C220
I have the old Audio 10 with cassette not CD and also wanted to play MP3's.
I briefly dabbled with an FM modulator (poor signal on the move) and finally settled on a good old tape-convertor for £5 at Tesco. Wish I'd done it sooner, it now plays anything at all that has an earphone jack. Sony Walkman, phone, a portable CD or Mini-Disk even!
The sound is actually better than the FM modulator and 100% consistant, regardless on reception.
This won't help you at all if your Audio 10 is a CD player of course ;-)
Jay Gee
N.Wales
Honda
Thank you Myros and W203-C220 for taking the time to reply. Yes,it's got fibre-optic capability,and yes it's a CD unit.Ah,well-something'll turn up.
