merc c200k
Tonight I was driving home listening to a cd whan all of a suddon the stereo switched itself off just as if I had turned the ignition off and removed the key. When this happened I had the audio menu showing on my dash but now instead of the track or radio station it showed four dashes like this ---- under the title audio. I pressed the volume button on the radio to turn it back on and that worked fine; stereo came back on and started playing the cd track from where it left off, however the dash menu still showed ----. When I switched the ignition off and removed the key the stereo remained on. Now I have to turn the radio on and off manually. The dash only displays the ---- on the audio menu and the steering wheel buttons no longer alter the track / station or volume. I have tested the buttons on other menu functions and they seem to work fine. HELP!!
I have a 2002 C200K W203.
Thanks.
Thanks.
