Auto box cable adjust
sigman
Kirkby Liverpool UK
Does anybody know the correct proceedure for setting the cable on the auto box of a 210 E240 .
IE what position should the lever be in when setting etc Thanks Paul
Problem is sometimes will not drop into 4th / 5th but does so if I go into N and back to drive
Your box is vacuum controlled if you have an early car, do you have the first 6 VIN numbers please
star
Reading
Smart + others :)
e240, electronic box, no vacuum or control cable.
Yes and correct thank you :D,I was thinking of the early 210's that had the 722.4 box as in the diesels
sigman
Kirkby Liverpool UK
Yes electronic box ,it has a small control cable at the nearside rear of box with a button
type lock mechanism ,according to MB manuals the adjustment can be a cause of my problem but no info as to how to set adjustment .Vin is 210261
OK I will look up the info in the morning, and see what there is
This could be just the shift of out of adjustment
I have a paper thatI can Email to you
sigman
Kirkby Liverpool UK
That would be great thanks , the problem is not all the time and if I drop it to N and back to D it drops in and will be ok for a while ,do you need my Email address ? still in 20th century I'm afraid .
sigman
Kirkby Liverpool UK
By the way the cable I have been adjusting seems to go upto an electronic unit front of shift ?. not the rod adjust .
If you can PM then do that,, if not just put your email address up here for 2 mins and you can delete it when I say
www.W140.co.uk&www.r129.co
