Auto folding wing mirrors
M
marines
Hi All
CLK 200 auto cabriolet 05 plate
The passenger side mirror will not fold when locking up been through the book and reset several times.
Any advice gratefully recieved ( new member)
Hi & Welcome,
Either a wire has broken (does it fold from the button?) or it could require lubrication. PTFE spray is very good for the lubrication side. Have you tried "helping" the mirror when you press the button to lock the car?
There is a guide in the DIY section for a wing mirror removal and wire repair.
As blobcat really,,if you need any info on getting yours apart as they are different to those in the link, then please ask, DIY is fine for fixing them if a wire is broken
M
marines
Many thanks
tried with button, then a little pressure, no good,
will now try lubrication,
then I think its off to the car doctor, as Im not goood with Mechanics.
Cheers
M
marines
Yes Yes it worked (the Lubrication) Many thanks once again.
Leaving the car for three months if I disconect the battery will I loose any information or settings
Marines
Cole@MBS
www.mbssouthampton.co.uk
Yes, you will have to reset the windows, steering angle sensor and no dout a few other bits depending on the spec of your CLK!!
No harm at all. when you charge the battery,take the top of the charge off with something connected like a tyre pump or bulb, then connect up to the car, though the battery may hold up the 3 months disconnected.
You will have to re set the windows and ESP and that is easy
Cole@MBS
Beat ya!!!!!:D:D
Cole@MBS
I know Sir,
Can you pm me your address so i can post them, i been to your place how many times now??
Still dont no where you live???
I know Sir,
Yus,,I will do that,,I still live there ;):D
