Auto Gear Selection
TaxiRichie
Vito 63 Plate
Hi, Hopefully the right part of the forum for this.
I have a 63 plate mercedes vito, automatic transmission.
This morning ive gone to move it and selected reverse, taken the park brake off, raised my foot off the brake pedal slowly and pressed down on the accelerator slowly but the vehicle just wont move.
it appears like the handbrake is still on, however its not showing as on. The handbrake pedal is fully lifted and their are no wheel chocks.
the vehicle hasnt been moved in a few months however.
all replies and tips to resolve helpful
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Did it move in d ?
T
TaxiRichie
Vito 63 Plate
Nope, no movement. Just feels like its trying to but the brakes stuck on?
John Laidlaw
Wirral
Land Rover Discovery 4
Parking shoe might be rusted on if the brakes were wet when you parked up a few months ago. Only suggestion I can give apart from dismantling it all is to put a piece of wood across the tyre then clout with a hammer a few times to see if that will break the rust seal.
onefortheroad
uk.
I'm thinking its in limp mode and therefore won't engage any gear .. unless the handbrake is stuck on.
M80
Derbyshire
You can often feel the parking brake release, more often with a thud as springs inside the drum pull the pedal upward. But if one is siezed not so much.
The thing is that MB parking brakes are notoriously cr*p unless they've just been set up, so holding the vehicle while you rev is unlikely to my mind. Overcoming the parking brake isn't usually difficult.
Try driving forward and then reverse a couple of times, you might hear that thud.
If one has seized you wont be able to strip it anyway.
Check the auto fluid level. If low it can fail to engage gears.
robin.large
CLS C63 AMG 2013
Sounds like your brake pads are stuck to the discs. Very common when left standing with handbrake on. Also much easier to free off going forwards!
So if you can only use reverse you may have a problem!
Sent from my ONEPLUS A5010 using Tapatalk
onefortheroad
uk.
Shoes.
T
TaxiRichie
Vito 63 Plate
Ccheers everyone, seems a block of wood and a hammer can fix everything
