Have auto open on my s211 2004 Estate that is somewhat temperamental and sometimes slams shut. I tried topping up the hydraulic fluid on the pump to no avail and do not want to go to the trouble to remove all the headliner to get to the worn out struts, which I think is the issue.
I understand the two inner struts open the boot (hydraulically by pump) and the two outer ones close it?
I have two s211's same year, same model (E320), one of them has the manual opening and this one has the auto open, think the manual opening is far better and the trunk slamming on the other one is becoming an issue.
Would it be possible to fit the manual open struts (stronger force, so the boot stays open) and do away with the inner struts or disconnect them and unplug the pump, does anyone know?
