Auto to Manual conversion, 300CE 104 Engine
rayhennig
1991 300CE-24 Sportline
Hello All,
I cannot stop imagining my old (290K Kms) 300CE 24 Sportline with a 5 speed (or later 6
speed???) manual box.
I have researched sources for numerous parts, including Mercedes' own "green" recycling plant
in Germany. I'm in France so geography isn't a problem and I'd be happy to drive to collect
good parts.
The big question is:
"What manual clutch/gearbox could be hung off the 104 engine without major cost/surgery?"
I have a very good, local garage where to father/son team love helping me with the car. They
know that my next projects are likely to be ATE/Brembo/Zimmermann discs, then Bilstein B12
suspension kit. But thereafter ...
The manual box is something I cannot stop thinking about.
It must be possible.
I don't think it's likely to be cheap but my view is that this car will be with me forever
and a few thousand Euro is far cheaper than any new or replacement vehicle, especially that
get close to the 124 coupe in terms of style and build quality.
Any ideas/warnings/encouragement/technical input would be very gratefully received.
Thank you in advance.
RayH
One of the hardest bits will be the center console, you may have to fabricate something for the top. it will be the same box as used on all of the 124's from 1987, I believe it was the same box used on the commercials with a different shift lever. the rear diff could have a different ratio, does that matter too much, the speedo could be out, but only you would know that. good luck with the project.
Malcolm
scotty2hotty81
I broke a 124 coupe up that had a dogleg manual gearbox coupled to the 104 24 valve engine went like stink, so it can be done with the right parts.
