Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
Sorry Col, would not have any experience with that, But see what Lost Kiwi has to say about the correct transmission fluid for your box. I'm pretty sure that they will have Dexron where you are? Its a worldwide brand.Ok ... last question...
Other than the oil pan gasket, are there any other seals that should be replaced? I read that the "front pump seal" is the most likely cause of my leak ... any idea if this is a simple one to replace (suspect it will be a PITA).
