autobox fault.
karlk
cambs
Hi, anyone had this code before. N3 speed sensor, Fault data reads problem with the planetry gears RPM readings. Not sure if this means that a sensor is at fault or the gears. any ideas anyone.
cheers
karl
Thatcham, Berkshire
1999, C240 Sport Estate
N3 speed sensor is part of the electro - hydraulic plate, you can get the plate for approx £80 but will require gearbox service aswell.
AS Kevin and not too bad a job,just the sump off, and do a fluid change at the same time
K
karlk
cambs
thanks guys, was hoping it was part of the valve / electric block in the gearbox as its under warranty.
karl
