autobox oil dark colour
Petemac
Inverness
merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
going to change oil in auto box drain the sump and turbine is plug in turbine housing adentified by a special bolt what filter do i need and sump gasket my model number is 1999 c250td VIN No= wdb202 1282f902609 there a lot on ebay but mybe merc garage will be best your advise is always welcome this is the first auto car i had thanks peter
Miffy
Bromley, London
CLK 320 CAB Elegance C208
why not just go and get them from MB, I dont think they are too over priced on the filter and gaskit?
P
Petemac
Inverness
thanks miffy any idea of total amount of oil i will need
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Be aware that the sump bolts can very easily shear, and it may pay you to replace the pilot bush at the same time. These are a very common failure point, and are about £20 from MB.
I personnally would only use genuine MB fluid.
You will also need a dipstick to check the level, as the dipstick is a specific service tool, though you can make one from a length of curtain wire and marking at specific points, the measurements are on here somewhere.
I don,t think you will find a drain plug on your Torque Convertor, so you won,t be able to completly drain the system, only the box itself. There is a way of cranking the fluid that won,t drain out but i,m not 100% of the method. Maybe someone else can give you a heads up on it.
P
Petemac
Inverness
thanks for all replies got dipstick on ebay £3 including p+p with instructions will use merc oil will be canny removing sump studs thanks again peter
www.ckinsurance.co.uk
