Automatic Gearbox Service
PJS MB
2013 C220 AMG Sport CDI Blue Efficiency 2.2
I'm looking for some guidance on how I can identify if my 2013 C220 CDI W204 has a sealed auto box or if it requires Servicing. My car system tells that it requires A) service shortly and part of that is ATF and Filter change but when I asked another Mercedes owner he said it was a sealed system?
Grateful for any advice.
malcolm E53 AMG
They all need servicing my view is <50k miles. My car has a 9 speed box presently on 42k miles and it will be done before 50k. My last car a 7 speed S212 had two transmission services in 80k miles and the box was as smooth as silk
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
Seem to remember I had the same issue with my W204, so I took it to an=n indie who drained the ATF (partial change) and then a month later changed the ATF again. Not very satisfactory but better than nothing.
Gazwould
C250 CDI
7g+ , ATF blue 236.15 , 5 years / 77,500 miles
Chrishazle
Nr Ashford, Kent
2013 is a facelift W204, which IIRC the owners manual specifies 1 transmission service (fluid and filter) at 37.5k miles and after that - nothing! Although my car is pre facelift that's what the handbook says, I had a big discussion with the service manager (MB main dealer) when buying the car as the service records did not show it as having been done, said service manager was adamant that pre facelift is "sealed for life" and only facelift needs service at 37.5k. miles. My indie said I did not need it done until close to 100k miles - which is what I did, autobox and TC plus filter.
Sealed system = sealed for death (or to get the car out of warranty period )
As above posts , they all get serviced now .
DSK
CLS 320 CDI, S350 Bluetec
Nothing is sealed for life! How do they get it in there. They must think every consumer is a dumbass.
My mum used to have a VW Vento (mk3 golf with a boot). There was no drain plug etc for the gearbox so I used to remove the pan, clean it, fill with fresh fluid and job done. Every VW service place said they can’t supply me oil as it’s sealed for life….
mioba
Nottingham and Köln
There is no such thing as a sealed system. It is sealed from the service schedule.
Do it every 35k end of.
It has a filter, oil, an oil pan.
Use yer loaf lad.
What did you decide buddy ?
AlanGunn
Anglesey
2013 C250 sport+ 2.1d
Mine is booked in for next Tuesday 16th.
Only had the car 6 weeks and 100k on it so i got it on the to-do list but that was the earliest date i could get.
No idea if it has ever been done before.
alcmackew
Eltham, Victoria, Australia
2012 S204 C200 CDI ESTATE
Mine was done at 125,000klms as recommended by Benz (7GTronic+) - new oil / filter etc.. still as smooth as silk on the changes...
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Use yer loaf lad.
If using red oil maybe. Not the good stuff . It's designed to last longer .
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
Speak with one of the recommended Indies and take their advice. I usually have my older S203 gearbox serviced by Cole at MBS. Pan off thoroughly washed inc magnet. New filter pan gasket and fresh fluid.
mioba
Nottingham and Köln
The garage will be able to tell you based on condition of old oil (colour, smell).
It is always a nice difference with new fluids, regardless of which.
hmang
^^^ This . How can old fluid possibly be better than lovely new clean stuff ? Same goes for the filter .
Sealed for life fans should take a look inside an oil pan for themselves when it comes off .
onefortheroad
uk.
Friction material from the clutch plates resides in the old oil , some say oil changes too frequently washes it all out and older gearboxes start to slip. It's written somewhere if you research it , but it usually ends up being a slagging match on here. :)
hmang
Ha ha
Yeah in the old days we used to put old pairs of tights in a knackered diff
Bay Leaf
Stockport
SL 350 R231 2013
Speaking of Diff's I had a 2004 S Type Jag and that only had a filler plug so I used to suck the old oil out with a syringe and refill. Jaguar also say the gearbox is sealed for life, I had mine changed twice over the eleven years of ownership by an Independent garage.
