Automatic Safety Belt Arm - w124
Campbell
Does anyone know where I can buy a replacement for the black plastic triangle guider that sits on the end of the automatic seat belt arm that extends when you close the door. My safety belt has finally worn its way through the plastic triangle and am using sticky tape to keep it in place !
maxicab
Lewes, East Sussex
Main dealer only as far as I know. They're not expensive - only a few pounds from memory - but more difficult than you think to fit.
rayhennig
1991 300CE-24 Sportline
Seat belt extender ...
Mine came with the new seat belt and the belt was already threaded through.
If not, how does one thread it??
Seat belt was 190 Euro (!!!) from dealer.
RayH
C
Campbell
Automatic seat belt guide
Yes v good question - how on earth do you thread the seat belt through the replacement triangle guider - does anyone know ?
jibcl500
Cambridgeshire
CL500,ML55,SLK280
undo the bolt at the end of the seat belt floor end.
jib
C
Campbell
Hi Jib
I looked at that option - have you actually done it cos the belt buckle and the seat belt end look a bit too big to thread through ?
jibcl500
Cambridgeshire
CL500,ML55,SLK280
see attached.
jib
C
Campbell
OK thanks for diagram - so as you suggested undo the bolt from the seat belt end in the floor and take the seat belt out from the plastic housing, unthread the buckle (as it looks to me as if buckle wont go through either), put it through the new triangle guider and then reassemble...
Will try that. Thanks
star
Reading
Smart + others :)
it does fit thru. trust me. :)
