automatic transmission
davidp
I have a 1990 230Te and the automatic gearbox has stopped changing gear. no obvious noise or problem just does not change up gear when accelerating. Any comment gratefully recieved.
Dave:-(
Number one have you checked the fluid level
D
davidp
Thanks - the oil level seems Ok when cold, does it change when warm?
karlefr
w213
Yes, always check the gearbox fluid when warm and engine running!!!!!!!
David you are going to need a specialist to look at it, where are you in the UK
D
davidp
The gearbox oil shows about 10mm below minimum when warm. Would this make a difference and is there a recommended oil? I am in Luton Bedfordshire
star
Reading
Smart + others :)
very slim chance, but check your kick down switch is not stuck down.
There is a good gearbox center in Ayelsbury
Ken Crossley STA Auto transmisions 01296 481145
Or this one in Luton.
Mr Nino Luongo
Bedfordshire automatics 01582 560224
They are both members of fate , good people and honest
http://www.fedauto.co.uk/
D
davidp
Thanks, I have it booked in for a test drivew tomorrow. Regards David
D
davidp
Thanks television. I took the car in as suggested to Bedford Automatics and now OK but £500 poorer. Thanks for all your help. Kind regards David
his wallet by the sounds of it lol!
You dont get much for £500 with an auto gearbox these days, and his problem was quite serious
dieselman
A diesel
At a guess it's the fibre governor drive gear in the tail of the gearbox. If the governor doesn't spin it doesn't allow any fluid through so the box never changes up.
Legoman
aye i know , just couldnt resist the joke when he said 'what did they find?' as most garages always milk ya for cash , i hate using them and where possible do all the work myself.
D
davidp
  • #17
Spot on Dieselman. The fibre governor drive was the problem
