automatic trunk closer not working.
Doc47
SL 300 2011
The trunk will open automatically but does not close when I press the swictch. I can close it by hand and the closer pulls it in when it is shut.
Does it close on the internal switch (push and hold)
D
Doc47
SL 300 2011
Doesn't close with the trunk lid switch or the driver door switch. Was working ok then just stopped. I took the switch off the trunk and shorted the cables but still nothing.
Adaption fault, needs further diagosis with a computer really.
D
Doc47
SL 300 2011
Could it be a fuse or relay.
mioba
Nottingham and Köln
Get the codes read. Sounds like the anti pinch strips which are a switch in effect.
D
Doc47
SL 300 2011
Thank you Mioba.
D
Doc47
SL 300 2011
Just an update, and info for anyone else who may get the same problem. I discovered two yellow relays sitting on top of where the vacuum pump lives in the boot (trunk). Replaced the one to the rear of the car and it works again. Yippeee.
