Aux belt change C270CDI
JoeHorner
2003 W203 C270CDI Elegance
Further to my post on "what have you done..." I thought people might find the following useful regarding changing the aux belt on a W203 C270CDI (may also apply to others)
I'd got a belt about a year ago but been putting it off because it looked like a pig and the book said lots of dismantling for access.
Today the car forced my hand.
Having managed to clear the bird's-nest of belt around the power steering pump I was faced with the problem of being just off the A55 with no proper tools - certainly nothing to remove the fan etc or move the tensioner.
After much swearing and head scratching I found that it IS possible - I'm fact, quite easy - to fit the belt round everything except the (smooth and accessible) water pump pulley then give it a good pull to slip it onto the water pump.
Clearing the debris took about 45 minutes, sweating took another half hour, once I thought to try that way actually fitting it took less than 5 minutes.
So, in future, changes will be:
* Cut old belt off
* Loop round and pull firmly onto water pump.
Easy-peasy
rifiki
Worksop
CLK W209 W121190B
Had same problem a few years ago. The idler pulley let go without warning and shredded the belt.
Fit a new idler pulley even if appears to be OK. You be surprised how small the bearing is.
JoeHorner
Will do but for yesterday it was a case of get it on, get it moving. I was on the A55 when it happened, headed to an athletics meet, and just managed to get off a slip road before temp got too scary with no water pump.
No tools, no breakdown cover, happened to have a belt (was planning to change it "when I had time") and about 2 hours to get moving and another 50 miles if I wasn't going to miss my first event.
So pulley & tensioner seemed like a fair risk to take in the circumstances!
The main take-home, though, was that it's possible (in fact, quite easy!) to fit a new belt without stripping everything the book says AND without having a suitable socket / bar to release the tensioner with :)
