Auxillary Fan hotwire-will it harm the engine?
Status
Not open for further replies.
MIKE236
Sydney, Australia
W124 230TE 1988
Hi All!
I posted my prob regarding the auxillary fan being on all the time. Well the prob stayed there for the past 3 weeks, after replacing about everything short of the fan and centre a/c switches. Anyway, one of the forum members..Erop, pointed me to a US website where this guy hotwired the AF to cut-in at a lower than normal temp. So..I thought why not since the fault could not be detected even by a MB speciallist here.
Anyway, after doing the modification, guess what the A/F returned to normal operations, i.e. following a/c usage and when engine temp goes up. My question to you all is since the a/f is cooling down the engine all the time instead and bypassing the normal way via the electromagnetic clutch fan (EMF), will it harm the engine in the long run especially the EMF mechanicals :?:
What the hotwire does is kicking-in the a/f at 92C and cools down the engine to around 82C. The EMF will usually kick in at 103C and brings down to 85C+. Therefore, the EMF never gets to be used at all :!: The hotwire virtually keeps the engine below 100C everytime even in a hot day and stop-go driving. Any thoughts from forum members is highly appreciated. Thanks all and have a nice day. Cheers!
GaryC
Manchester
Hello,
It won't do any harm to the engine, as the thermostate (The one which control coolent flow) will not allow any coolent flowing into the radiator, below 80 to 85 degree C, so whatever the temperature of your radiator, if the coolent was less then 80 to 85 degree C, there was no cooling action for the engine.....
Hope this could help...
Gary!
M
MIKE236
Sydney, Australia
W124 230TE 1988
Hi Gary.
Thanks for the clarification mate! Since I am new to this DIY stuff, all the help received is greatly appreciated. Thanks again and regards.
john.clarke
Pietermaritzburg South Africa
Aux Fan Hotwire
Hi Mike....at 236 YOA you should be past DIY..........
.....glad to pick up on your prob.......my climate is similar (Africa) and had been thinking of some mod for the AF myself.
I would be most grateful for details of the hotwire.
Don't fret at 65 I am starting to struggle with wriggling around a 1995 E220 W124.
Tyke in Africa
Status
Tel: 020 8863 9233
