B-Class W247 headlight level aim low
nikolaus
B-Class 2019 B180
Hi, my W247 B-class is still in warranty, I found that the headlight aimed a little low, hall I adjust myself or I have to take it to the dealer ? Will the dealer charge as service ? Thanks.
Hello and welcome,
Do you have an adjuster by the light switch (I don't know the B-Class layout)
Do you have LED lights?
You can ask the dealer, I can't see them doing anything for free - although no harm in asking...
EmilysDad
Bury Lancs
ML350
... assuming of course that nothing is broken inside the headlight. I've had an adjuster break inside the headlight due to heat over the years which ended up with the reflector flapping about inside & pointing to the deck
mioba
Nottingham and Köln
If its manually adjustable (which I assume) as its on one side. I cant imagine it takes long to rectify and a fair dealer would do it for free as its such a small job. note the word fair.
Failing that if you can DIY it then park near a wall lights on and go for it.
If its a broken part leading to the fault - could well be covered.
N
nikolaus
B-Class 2019 B180
Hello and welcome,
Mine is the standard stock LED headlight
