tttonyyy
- Mar 31, 2019
- Location
- Southampton
- '03 ML270 (owned from 60k miles, now on 90k+)
Had the ML270 for 18 months now, sorted the swirl flaps and running 100% biodiesel no problem (aside from having to periodically rebuild the high pressure pump - the head seals deteriorate quickly).
Since ownership it has always "slipped" a bit in 4th, IE overrevved - like a clutch band is slow to grab. More recently it's started to go into limp mode (2nd) reporting "improbable gear ratio", which cleared when stopped and restarted.
Now it's permanently in 2nd. And my expensive iCarsoft MB V2.0 had the screen flicker and die so I can't see what else it's reporting.
I've dropped the transmission pan and the valve body, removed and tested the solenoids (they're all fine, as far as I can see). There was quite a lot of very fine metal sludge both stuck to the magnetic trap at the bottom of the pan, and all over the magnetic sensor that peers up into the gearbox (presumably to sense RPM). Not good for a box that has only done 70k.
Additionally, there was quite an ATF leak past the wiring loom bushing.
I've cleaned it all up, put it all back together (with new bushing), put in new ATF (torque converter flushed via pipe on ATF coolant return). But alas, still stuck in 2nd.
I don't really want to give up on the old girl, but I'm at a loss what to try.
Some photos.
Underneath of box with valve body removed. I assume that the rectangular holes visible behind the circular holes are used for RPM sense. That they're in this position perhaps implies that the thrust bearings haven't allowed the shafts to slide them out of view of the sensors?
Valve body, note the magnetic swarf on the RPM sensors:
Solenoid valves out, each was a few ohms of resistance and I blew through them with an airline
All refitted with new pilot bushing and filter:
More metallic sludge from the ATF coolant return
ATF going in
ATF from torque convertor coming out
Some photos.
ATF going in
