bad vibration
wilko
i have an slk 230 komp and ive recently drove over something- there was a bang... and now something is vibrating at 1800 revs.. its not the exhaust tho ive checked, the noise is coming from underneath passenger seat ..
Parrot of Doom
Manchester
Maybe its a squirrel corpse flapping against the undertray...
The propshaft is about the only thing, one of the UJ's adrift? spider broken ?its got to be around there some where. something jammed under the shaft ?
malcolm
carabind
Lancashire
e class
Exhaust could also be possible, if the jolt has disturbed the internals when you have driven over something. Does it do it at 1800 revs all the time (ie in neutral, 1st, 2nd etc) or only say at 1800 in 4th gear?
Also, is the rear mount on the gerbox still OK ?
sankey said:
could be the seat going through the floor,,is the car rotten..[badly corroded]
If you think they are so bad, it shows what an idiot you are for spending £50k on one.
malcolm
