Dean Fletcher
- Mar 24, 2018
- Location
- Penrith, Cumbria
- Mercedes E400
- Thread Starter
- Thread starter
- #21
Thanks Jim, after looking last night I cannot see any signs of water near the water pump or radiator, I can see liquid on the under tray directly under the fuel filter and where the photo is showing. Its hard to see on the photo but with a torch you can see the water clearly pooling where I pointed out. I had a new water pump fitted probably 18 month a go.When mine leaked, it showed very little outward signs of leaking, and I am not sure from your pics if those stains are coolant or not. Chances are that they are though. Only way to confirm it will be to remove it and check the seal.When you have a leak like yours, should be obvious..damp carpets, strains around the water pump,header tank cap, radiator etc. If those are not present, it's the filter housing, and as the car will be moving, the water will be dispersed.
