Ball Joints
Beresford
Sweden
i have just been told by MB sweden that my front ball joints need replacing. They have said it will cost approx £330.00 per side .My steering wheel is noisy when turning at slow speeds and the drivers side(lhd) front of the car makes a squeaky noise also when going over bumps.
Can anyone offer any advice?
Is this something i can do myself?
Is it a fairly straight forward job that i can take to a good Independent?
PLEASE HELP an English man in A very cold Stockholm!!!
Cheers Beres
B
Beresford
Sweden
  • #2
CAR Info
Sorry i forgot to include this:
158,000 km
W124 Estate '94
LNM
Birkenhead.
Beresford
I'd take it to an independent; what's the point in paying MB labour charges at £75 per hour ?
B
Beresford
Sweden
Solved
New ball joints on either side solved the problem.
It cost me around £250 with an MB independent.
Just incase someone was interested in the outcome!
Cheers
Kully E220 Coupe
Ball joints squeaky
My car has just started making spqueaky noises when going over speed humps even though i drive at 5 mph over them, also i get a squeaking from the nearside wheel when turning right? Is this going to be a ball joint replacement?? also i changed my tie rod ends last year will i need to replace these aswell?
Kully:confused:
Kully E220 Coupe
Quick question just been reading some post about ball joint replacement and SPRINGS would i need to take the spring out or go anywhere near it when changing the ball joint because i dont want a spring impaling me!!!! my mate told me how he was changing a front spring on his CE and he was using 2 sets of clamps and the spring still flew out and bounced off the floor and straight into his garage wall!!! I have lowering springs installed so does this mean they should be easier to take out as they are shorter (the car is 100mm lower than standard)
Kully
Falco
I put mine into a garage with the same symptoms and they couldn't detect the problem. Week later out on the road the lower balljoint snapped with catastrophic consequences. One garage wouldn't even do the work-said it was too much for them. The price you've been quoted is maybe a bit high but not outrageous!!
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Bearing in mind the ball joints are £13 each* and labour is about £70 / side it seems a tad expensive to me...
* Some cars do have unremoveable balljoints and need a complete wishbone replacement
Nick Froome
www.w124.co.uk
Kully E220 Coupe
Nick Froome
www.w124.co.uk
I've decided to get the wishbone replaced instead of fiddling around with the ball joint, i'll be doing this on the weekend and i will take pics and make notes on what i did and post it up here :p
