Banging noise/ Driver window
mike102
polperro cornwall
1990 300 E class
Dear Members.
My drivers side window is making an awful banging noise as i bring the window up. It strains it's way up only to suddenly stop about an inch from the top, yet the motor is still running and bangs/thumps, you can see it pounding the inside of the door facia.
I am able to pull the window to the top by hand and manually back down, so seems like iv'e got a problem.
Anyone relate to this.
Thanks.
Mike.
It will be the teeth stripping on the closing system
mike102
mike102
polperro cornwall
1990 300 E class
Thanks Malcolm.
Is it a DIY job or a visit to the shop.
Mike.
wireman
lancashire
Diy if you want to do it, you need a new regulator OR a good welder can put the teeth back on your old one.
I can give you the info if you would like it
mike102
mike102
polperro cornwall
1990 300 E class
Malcolm, Just got back on-line.
Yes please, any info would be appreciated.
Regards.
Mike.
Smudge
One being broken on ebay
Item number 290330466432
This one is an estate but the front regulators will be the same as saloon.
mike102
mike102
polperro cornwall
1990 300 E class
Malcolm.
Whatever info you got,
will be grateful for.
Mike.
I will be sending it in a few mins :D
2 papers sent what you can do for now is to remove the winder and prop the window closed with a lenght of wood
mike102
mike102
polperro cornwall
1990 300 E class
Malcolm.
Not sure where i retrieve the papers from.
Do i go to a different section or will they come through on this thread.
Thanks.
Mike.
I sent them via Email so could be in junk box
mike102
mike102
polperro cornwall
1990 300 E class
Cheers Malcolm, Never thought of checking their.
I'll go take a look.
Mike.
mike102
mike102
polperro cornwall
1990 300 E class
Malcolm.
Got them, I'll have a good study, and all being well can have a go whilst avoiding this crummy wet weather, nows the time i wish i had a garage.
Once again, thankyou, and will let you know how i get on soon as possible.
Best Regards.
Mike.
Xtractorfan
S class
Dear Members.
Thanks.
Mike.
Had a similar problem but it was only the missus banging on the window to tell me my dinner was in the dog....
mike102
mike102
polperro cornwall
1990 300 E class
xtractorfan.
Wish that was the case on my part, Deserves a chuckle all the same.
Mike.
tiswas
1999 280 SL
2 years ago I was told that the regulator needed replacing on my 99 SL drivers window and then 2 months after that the motor went.
I now have that banging problem with the passenger side. This time the indie says it is the teeth on the motor, which ties in with what Malcolm said above, but I am confused as to why someone else is talking about the regulator for the same problem.
Sorry but I know bu***r all about these things!
Rob
PS Just been quoted £201 by Merc for new motor, cannot get one anywhere else.
Sometimes when the door has memory windows it can be called that as it combines some electronics
teddycatkin
cheshire cheese country
No big deal with this one a common problem-Take it out as TV says but remove the fuse 1st to isolate the motor --its seperate and the other windows will work ok while you do the job --just wedge the window closed with 2 small wooden pegs and you can still use the car.---bit of a fiddly job getting it out though --check the teeth on the ratchet system --you will find the end ones worn flat--(causing the small cog on the motor to turn jumping them and causing the banging) The options are weld the teeth and shape them up to match the others --cut out the bar with the teeth in and weld a new set in or turn it round the opposite way so good teeth are at the top ---or change the whole unit for a good 2cnd hand one.
tiswas
1999 280 SL
So £200 from Mercedes plus fitting cost is the going rate for those of us who struggle with changing the brush head on my electric toothbrush?
Tel: 020 8863 9233
