bas esp,abs lights on
swanc220
Hi all as the title says the bas esp and abs warning lights have come on my c220 cdi W202 . they started of intermittent but now stay on all the time, There's a new battery fitted and after reading posts on this problem a new brake light switch. I have also tried moving the steering wheel from lock to lock many times, has anyone got ideas as I don't really want to take it to the dealers thanks in advance jt
The chances are that the fault is only a wheels sensor, or broken wire on a front sensor, whey not take it to an indie, they are much cheaper than the dealers
swanc220
thanks for the quick reply, now can anyone recomend a good indie in the swansea area please
swanc220
Thats not to far away about 35 miles, thanks again
Xtractorfan
S class
There is a similar post on here to yours and it turned out to be a faulty steering angle sensor..
swanc220
ok thanks for all the advice. I'm gonna try and find a indie close to swansea , then I shall report back with the diagnosis, hopfully not too expensive
swanc220
Ok just a update for the records, faults came back as,1 reinitiate steering angle sensor. 2 front right abs sensor faulty. I had both these faults corrected and now touch wood it seems ok, the abs ring was also rusty so needed cleaning up. Total cost £140 form a indie in swansea , thanks all for the advice
Thats good news :D, can you say who did the work please to help others
