BAS/ESP Malfunction
I second it, £8.75 plus a 17mm spanner and be prepaired to spend ten minutes working over the brake pedal.
Malcolm
piestore
manchester
ml bas esp
I would agree most likley brake light switch after that speed signal or high pressure pump fail which is quite common on older vehicles, OK relax its not actually the pump at fauly just a relay in the fuse box from memory its K26 (but don;t quote me on that) stand at the front of the vehicle and open the fuse box rear most row second relay from right (don't quote me on that either) please note these change due to model and year
Tel: 020 8863 9233
