Battery change using OBD ?
Simon Barry
midlands UK
CL500 215
Is there a procedure available to avoid coding loss when using an OBD scanner (Icarsoft) ?
I appreciate that Star does it.
I do not want to visit main dealer.
Simon Barry
midlands UK
CL500 215
How do you mean coding loss?
Memory loss.
Inasmuch ability to store current memory & transmit it when new battery fitted.
Avoiding purchase of memory tool
Memory loss.
Just connect another 12V battery to the connections under the bonnet when you change the battery to save on settings
(Just remember the +ve lead is still live when you take it off the old battery so don’t let it touch the.bodywork…)
AMGeed
Poole, Dorset
S204 C180K
The only possible memory loss when changing a battery without using the method in the above post is the windows and sunroof may need resetting.
A simple job if required.
Chrishazle
Nr Ashford, Kent
Whatever you do, do NOT connect a 12V battery to the OBD port, Halfrauds did that to my S204, cost 2 days of hassle and they had to refund the £175 it cost at my indie to undo the damage they'd done!!
mattkh
England
A160 W168 1999 1.6
And the code for the Radio..????
Simon Barry
midlands UK
CL500 215
Thank you all for the helpful replies, points all taken, will proceed....
