Makes sense but the manual specifically says ONLY use the under the bonnet connections as does this video for some reason -I personally would go for "straight to the Battery" - path of least resistance is normally always the best route...
Two main reasons why advice is to use the terminals under the bonnet and not the battery terminals directly is for the sparking potential and accidental ignition of explosive gasses collecting around a battery, secondly as it is usual practice to connect the Negative terminal last, this is where the battery sensor is located and sparking at this location can at worst damage the battery sensor or at least cause anomalies with the systems reliant upon the sensors designed performance, to be safe, if charging a car connected battery it would be advisable to disconnect the battery Negative terminal from the battery taking the battery sensor with the post clamp or if you have under bonnet charging points simply use them. It makes no difference where the connection is made with reference to post 4, any consumers left working are going to 'suck juice' regardless, electricity doesn't work that way. I personally wouldn't use ANY output socket of a vehicle, OBD or Cigar Lighter to feed a secondary independent supply of any description back into a vehicle, this is wrong on so many levels, you are creating backfeeds, energising untold amounts of additional circuits connected to the same vehicle distribution units without correct fused protection and with supplies from battery chargers that may be providing unregulated outputs, voltages in excess of the vehicles components normal operating parameters, and/or of a questionable quality, using 'half wave or modified rectification' to produce pulsating DC, this may be sufficient to charge a Lead Acid battery but can do untold damage to sensitive electronic components.
My C-Tek is clipped directly to the Consumer battery in the boot. I've been doing that for three years. It works wonderfully. If there was a custom made charging point, I'd use it.
On your 2016 car there will be under bonnet connections as per the post #7 video so use them.Hi,
Can you trickle charge a C43AMG via the power socket or do you have to go direct across the battery terminals
Just wondering if my elderly car (2004) is somehow more robust than later models. It has wondrously complex consumer functions but doesn't exhibit the temperament you're describing.
