battery drain sl R129
mglb
w yorks
further to my battery drain problems which settles to 220ma when left the load appears to be accumulative the major drain being the fuse 3 in the rear fusebox [power soft top controller and solenoid valves ] the controller was replaced last year before I bought the car ,could anyone advise if putting an ignition controled relay into circuit 3 would be okay or should I start looking further fuse 3 is taking 100ma .Is 120 ma an acceptable drain? and where is the controller for the softtop situated thanks
mark
stats007
Hampshire
Looking
The drain sounds perfectly acceptable to me.
The soft-top module N52 is under the rear seats / storage bins on the offside. I wouldn't recommend fiddling with this unless you know what you're doing. A repair is £500 on an exchange basis for these.
