I am new can anyone help is it normal for the battery to go flat on a 2000 sl 280 if nor run for about 10 days the battery has been checked and is ok
Ian
No, a proven good battery shouldn't go flat over that period.
Do you have a hidden power drain? (other than the alarm). Is your glovebox light or boot light switch faulty, leaving a bulb on all the time?
Doug
I had a problem last year where my battery was low, the car was drawing 5 amps with everything off and the car locked.
It ended up being the central locking pump unit not switching off when the car was locked. Seemingly this unit primes the ECU and everything else electrical prior to starting and also shuts down everything when the car is finally locked.
Replacement was £360 from the main dealer. I had already replaced the battery prior to the diagnosis.
The 230 has a seperate starter battery in the front which should start the car if the consumer battery is flat. The 129 is far less complicated and as malcolm should last a lot longer then that.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
