Battery light on my E220
My battery light keepster coming on when i start the car
  • Only when car has been in garage for few days
    Votes: 0 0.0%
  • Goes our after start
    Votes: 1 100.0%
  • Total voters
Peter Rushby
E220 cabriolet 2018
On start up my battery light comes on and says check owners manual
If the car has not been Used for a few days
68 plate and is garaged
Hello and welcome
Have you measured the battery voltage?
Quite a few batteries have failed with less usage due to lockdown.
Much less than 12.6 V at rest with engine off can cause multiple errors
P
Peter Rushby
E220 cabriolet 2018
Hello and welcome
Its a brand new battery and the Mercedes garage have tested it on the computer and say then cant find a problem ? But on one occassion after a week in the garage it wouldnt start
P
Peter Rushby
E220 cabriolet 2018
Battery light prob
Sounds like you have a parasitic drain then... It can take awhile to work out which module isn’t switching off or switching back in again
If you can fit a battery conditioner then do so as that will keep your battery up to voltage.
P
Peter Rushby
E220 cabriolet 2018
Thanks for you help i Will check with Mercedes
mioba
Nottingham and Köln
Just out of interest how many is a few days.
P
Peter Rushby
E220 cabriolet 2018
It can take sometimes 3-4 days of no activity in the car
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Welcome, get a battery optimiser I believe they are about £15 in Aldi at the moment.
Leave it connected overnight, see if the error code appears on start up. If not you have a drain somwhere.
mioba
Nottingham and Köln
the fact there is an error after a few days shows a drain. A battery should be good for at least a couple of weeks Is standing at cranking.
As Blobcat says. Have you tested the V
Had this issue only been since you replaced the battery.
A.J.
Norwich. UK
Hi Peter, welcome to the forum :)
P
Peter Rushby
E220 cabriolet 2018
What does the optimiser do ? Would the error code be from the optimiser ?
Will I need to connect the optimiser to the battery and if so , do I need to make sure I connect it without doing anything else
The light started to come on 7-8 months ago after it was not used for a few days . I took it intro Mercedes at least 6 times to check and i suggested then replace the battery . Which then Saïd They did.
It then came on again after several days of no activity
And has been coming on after being stond for 2-3 days .
Mercedes claim they cant find the fault
We have a similar issue with our 230.
If left overnight the auxiliary battery takes consumers offline. We found that turning off Comand then allowing the battery to go flat then recharging it the battery would hold for over a week unless Comand was turned on again.
A little more investigation has pinpointed it further to be the CD multi hanger.
These things really are only solved yourself by trial and error and patience.
Rather than take it to MB (who in my experience are pretty hopeless unless "Star says..." take to an auto electrician who will have the knowledge and skills to trace this type of issue.
sonic
Staffordshire
The optimiser is a very intelligent battery charger, apart from charging it conditions the battery as well. Once the battery is fully charged it switches off but monitors the battery state. When the charge in the battery starts to drop it starts charging again.
You connect it to the battery leave everything else turned off.
On my E class I can leave the bonnet up with the car locked & alarm set in the garage.
For £15 its worth having anyway, & it may solve your problem. As LK says MB are pretty crap at solving electrical faults, you need an auto electrician.
But try the optimiser first, if this solves the problem & you have a new battery it must be a current drain somewhere.
The battery on my E class is 9.5 years old, my wife's SLK battery lasted over 9 years. Optimisers really do work & prolong the life of a battery.
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
As above from Sonic. The battery in my now departed C280 was 12 years old when l p/xd the car earlier this year and I'm sure the CTEK charger/conditioner helped it to last this long. Of course, a good quality battery helps as well, mine being a Bosch.
P
Peter Rushby
E220 cabriolet 2018
  • #17
Guys apart from the battery light , now just started when in the car with engine running my passenger got out and shut the door , the heated seats and the heated head rest came on full , Whats that all about
See my new problem I’m sure these are all linked
Various unrelated circuits interacting is almost always either a bad (wet?) SAM or bad earths.
They would be my first ports of call.
P
Peter Rushby
E220 cabriolet 2018
  • #19
SAM?
Signals and Acquisition Module.
It controls many functions of the vehicle and in most cases there are two - one for the front of the car and one for the rear.
They are generally part of the fusebox and contain control electronics, fuses and relays.
