Hi, I disconnected my battery to charge it, but then the boot got closed.
Now I cannot open boot as no power, and key lock doesnt work.
Where under the bonnet is there car jump starting points?
Thank you that workedSee top right hand corner. Under this cover is the Live, (POSITIVE) from the Battery. You CANNOT jump start from here but you can supply 12V to open boot. Use any good Earth in Engine Bay.
How come your Wiper is at rest on the wrong side of the Windscreen...?
The jump point on the 202 is on the nearside near the bulkhead / suspension mount. It's a little black box with a lid which you can spring open. This is a positive terminal and you can use any convenient chassis point or the engine as the negative.
