Battery sign lit up red on malfuntions?
DaveE320CDI
york
2004 E55 Kompressor
Hi Everybody, Just bought a w211 e320cdi 2002 model, few problems allready first being that the car is showing one malfunction a" red lit up battery "emblem in the speedo? car starts ok was thinking maybe last owner fitted a new battery and fault code still there? is this possible? Also something not electrical the key for the wheelnuts is missing! and i need the wheels off to put new tyres on, i have tried the dealers for a matching key but no luck and they want to charge me £97 to smash them off! any better ideas very wellcome many thanks Dave
The red sign would suggest that the alternator may have stopped charging, if the wheel bolts are all non MB then I dont know what top do about that
Cole@MBS
www.mbssouthampton.co.uk
The regualtor is common for your fault, about £40 for the part, as for the wheel bolts, you can buy a set of extractors for locking wheel bolts!
D
DaveE320CDI
york
2004 E55 Kompressor
Check for charging with engine running and its showing 14+volts so alternator OK, the locking wheel bolts are genuine Merc thanks Dave
Cole@MBS
Yes agreed, your getting an output voltage, the regultor is still causing the warning light!
D
DaveE320CDI
york
2004 E55 Kompressor
OK, Yes i follow what your saying where is the regulator located cheers Dave
Cole@MBS
On the rear of the alternator, held in with 2 screws, has the main lead bolted to it!!
D
DaveE320CDI
york
2004 E55 Kompressor
Many Many thanks! Dave
Cole@MBS
Sent you a pm dave about the wheel bolts!
