Battery voltage
Merc mat
E220 2012
Ok I have issues with no stop/ start
Not going green ,iv tested both battery the auxiliary is saying 12.8 and the main 12.00 I think at 12.00 it's a little low , but I didn't think the main battery affected the stop / start the car is a 2012 e220 ,
12 is almost dead buddy , what date is on the terminal
malcolm E53 AMG
I’ve found that the condition of the main battery on the 212 is a big factor in whether stop/start is available. I replaced my main battery last year and stop/start hadn’t been available for quite a few months prior now the indicator shows it’s available within a couple of miles. Incidentally I switch it off as soon as the indicator shows that it’s available to save the engine - acts as a good battery indicator though.
Varta or Bosch are the OEM batteries I used Tanya online to order mine, best price and next day delivery. Regardless of where you buy from top the battery charge up for a couple of hours before fitting it makes all the difference
Gazwould
C250 CDI
Just replace the battery when it starts cranking slower , no stop strain is an excellent thing .
Merc mat
Merc mat
E220 2012
Not sure of date this is a picture of it , I do no it's never been replace , as it was my father in laws car,
I'd have the tops off the cells and and fill with de-ionised water
EmilysDad
Bury Lancs
ML350
The date is normally stamped into a terminal post in the same format as a tyre ie 4 digits, week number of the year & then the year number ie 5020 would be week 50 of year 20
malcolm E53 AMG
Yes 8 years service is good for a battery if you’re keeping the car I’d replace with the same Varta battery, shop around for price but Tanya take some beating re price and delivery
Merc mat
Merc mat
E220 2012
Thanks guys, so it looks like new main battery time, I did recheck the voltage direct off the battery and it read 12.15 , thats still a little low ?
Very low - 12.6 is what you're looking for
Gazwould
C250 CDI
Not necessarily .
Strongly consider buying locally in case of issues .
Is it not a sealed unit ?
Yes and no...:rolleyes:
You can cut around the tops of the cells (the sticker) then use a chisel (or screwdriver) and hammer to knock the cell tops anti-clockwise to unscrew.
It messes the cell tops up but only cosmetically. You can then fill the cells up with de-ionised water and I expect the battery will come back to life.
I expect the tops of the plates will be completely exposed with no visible electrolyte at all.
Fill it up to just over the plates and leave it 1/2hr then measure the voltage again.
Tel: 020 8863 9233
