markben
- Feb 12, 2017
- Location
- Bristol UK
- w220 2004 S320L CDI
Christmas Greetings all.
Another Battery query in case any of you are tuning-in in between the Festivities....
To recap: New battery fitted 3 weeks ago when the previous one failed (after 6 years). New battery failed after 2 weeks, recovery service called out twice within 48 hours to start the car, battery replaced under warranty in case it was a ‘bad’ one. 48 hours later even after a 2-hour fast journey in daylight, second / new battery was dead this morning. So.. not the 2nd new battery, more like a battery drain problem?
Co-incidently (?), for the past few weeks my manual boot release button hasn’t worked so I’ve been using the remote button on the key fob.
I spoke with a helpful auto electrician by phone today (Indies etc are all closed for the Hols), gave him the recent battery failure history AND mentioned the boot opening button problem in case it’s relevant. Immediately he said that probably… (stress Probably), if the manual boot release button was stuck / faulty, the boot / trunk interior lights (2 x 5w bulbs) could be staying ON when the is boot is closed & the car is switched off / left overnight. So.. remove the bulbs to stop a possible parasitic current draw, charge-up the (second new) battery and see how it goes. The PSE pump works ok on all the other functions and is silent when the car is switched off.
The latest problem.. a few hours' trickle charge today and the battery voltage won’t go above 5.9v. It’s a lead acid 90mA lead acid OE spec (before you say it.. yes an AGM would be the ideal choice but the Nat Tyres / Halfords recommended one was an expedient). And... both new batteries may be ok if not for the suspected parasitic drain problem? You tell me...
Any thoughts & ideas welcomed
Many thanks and YO-Ho-Ohhh… No-No-NO!?
MB
MB
