Becker Radio Problems 1984 500SEC
Status
Not open for further replies.
cllcpa
Radio just makes a click when turning power on. Antenna does not work at switch Checked #15 fuse and is OK. Is there anything I can check?
If not can you give me instructions on how to remove radio
talbir
London
There is a usually a fuse on the back of the radio itself.
The standard Becker fitment can be removed quite easily -
- pull out the ashtray and lift out the chrome tray inside
- you will then see two Phillips screw. Remove these
- now you can pull out the entire ashtray housing
- once ashtray is removed, directly underneath the front end of the radio, inside the gap where the ashtray was, you will see two shiny metal clips, one at either side of the radio. Push these clips down and simultaneously pull out the Becker system.
That's it - you can then check the fuse on the back of the radio and check that power is coming to the loom at the radio.
Status
