rich.g.williams
- Oct 25, 2009
- Location
- Cardiff, South Wales
- C200 Kompressor Coupe 2003
The W203 ABS Wheel Speed Sensors have an IC chip (Hall effect) inside. It's not possible to bench test them with a meter on Volts or Ohms. Attached is a simple circuit showing a way to test them. Please note this is to test them on the bench not connected in any way to the car. Avoid bringing a strong magnet too close to the sensor just in case, a few mm away should show a strong switching response. Any comments appreciated.
